I have numbers longer than 16 characters in my database that I need to use in n8n, mainly to compare which is bigger. But, since they are greater than JavaScripts max integer value, n8n represents them incorrectly. How can I use them in a filter to correctly compare which is bigger, and/or read then use the value in a HTTP request.
The HTTP Request doesnt recognize the value because N8N displays the last 3 numbers as 0.
- n8n version:0.222.3
- Database (default: SQLite): SupaBase
- n8n EXECUTIONS_PROCESS setting (default: own, main): main
- Running n8n via (Docker, npm, n8n cloud, desktop app):docker
- Operating system:ubuntu
