How to connect redshift db using postgres connection
I have n8n hosted in my VPS, and I want to connect to redshift database. Since there is no redshift node, I am trying to achieve this using postgres node. I could not find any detailed explanation on the same. Could you please help me?
You can connect to Redshift using the PostgreSQL node since Redshift is PostgreSQL-compatible. Here’s how:
1. Use the PostgreSQL node in n8n
2. Set the host to your Redshift cluster endpoint
3. Use port 5439 (Redshift’s default)
4. Enter your Redshift database credentials
Make sure your VPS has network access to the Redshift cluster. If you encounter connection issues, check your Redshift security groups and VPC settings.
Give that a try and let me know if you run into any specific errors!
