Hi all!
I need to connect to the Pinecone vector store to perform different operations - for example, delete some vectors or completely delete all vectors from some index.
I can do this using simple python script:
import os
from pinecone import Pinecone
from dotenv import load_dotenv
load_dotenv()
# env var
api_key = os.getenv("PINECONE_API_KEY")
# init
pc = Pinecone(api_key)
index = pc.Index("my_index_name")
# clear the index if it contains vectors
if index.describe_index_stats().total_vector_count != 0:
index.delete(delete_all=True)
else:
print("The current index in the Pinecone vector store has no records.")
How can I do the same using the Code node in n8n?
I tried something like this to setup connection:
const Pinecone = require("pinecone-sdk");
const pineconeClient = new Pinecone.Client("MY_API_KEY", "MY_INDEX_NAME");
pineconeClient.connect();
However I get the error: “Problem in node ‘Code’. Cannot find module ‘pinecone-sdk’ [line 1]”.
I also tried setting environment variables to allow importing built-in and external modules:
export NODE_FUNCTION_ALLOW_BUILTIN=*
export NODE_FUNCTION_ALLOW_EXTERNAL=*
However I get another error: “Problem in node ‘Code’. ‘import’ and ‘export’ may only appear at the top level [line 1]”.
So, can someone help me implement the same logic as in my Python script but in the Code node?
Information on n8n setup
- n8n version: 1.42.1 (Cloud)
- Database (default: SQLite): NA
- n8n EXECUTIONS_PROCESS setting (default: own, main): NA
- Running n8n via (Docker, npm, n8n cloud, desktop app): Cloud
- Operating system: NA
