I’m using the IMAP trigger and retrieve data there e.g.:
"textPlain": "Hello, \n \n \n \nKind Regards\nOur website: https://domain",
Then, I want to POST this data with an HTTP request into an API.
"name": "{{ $('Email Trigger (IMAP)').item.json.subject }}",
"description": "asdf",
works fine.
"description": "{{ $('Email Trigger (IMAP)').item.json.textPlain }}",
throws an error:
JSON parameter needs to be valid JSON
I’ve tried this:
"description": "JSON.stringify({{ $('Email Trigger (IMAP)').item.json.textPlain }})",
But it throws an error as well.
Is there a good solution to make that future proof?
The plain text and the HTML mail?
- n8n version: 1.72.1
- Database (default: SQLite): PostgreSQL
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Operating system: Ubuntu 24.04
