Is this done via Http-Request?
Thank you.
Thank you.
Hi @ManyQuestions
yes to create/update the excerpt of a post you need to query the WP APIs with the HTTP Request node.
You need to use the endpoint:
POST /wp/v2/posts/<id>
passing the excerpt value
More info here: Posts | REST API Handbook | WordPress Developer Resources
Let me know if this helps and you need more support
Best
Thx for the reply. The credentials and the Post ID are ok, but for some reason, I am still getting the Error: ERROR: Authorization failed - please check your credentials
{“code”:“rest_authentication_error”,“message”:“Sorry, you do not have permission to make REST API requests.”,“data”:{“status”:401}}
Hi @ManyQuestions
are you using an “Application Password” for your credentials?
Some links:
Let me know if that helps
All the best
Yes i use application password. It’s working when i want to create a new post, via the wordpress node. Is there anything i need to do different with the authentication using https modes?
Hi @ManyQuestions,
here’s how I configured the HTTP Request Node to make it work:
And this is how I configured the credentials:
Best
That’s working. Thx alot!
