services: n8nio-n8n: image: “n8nio/n8n” restart: on-failure ports: - “80:5678” environment: DB_MYSQLDB_DATABASE: xxxxxxxx DB_MYSQLDB_HOST: aws.connect.psdb.cloud DB_MYSQLDB_PASSWORD: xxxxxxxxxx DB_MYSQLDB_PORT: 3306 DB_MYSQLDB_USER: xxxxxxxxxxxxxxx
How to set DB_MYSQLDB_SSL OR DB_MYSQL_URL
DATABASE_URL=‘mysql://:@aws.connect.psdb.cloud/?ssl={“rejectUnauthorized”:true}’
or how append “?ssl={“rejectUnauthorized”:true}” on environment
Hey @bkk.pyu,
Welcome to the community
If the database is using a trusted certificate it should work but at the moment we don’t have the SSL options for MySQL. This is something we do have Postgres though which might be a better option if you are setting up a new environment.
