How to do scalabilty in n8n while active and running multiple n8n workflow?
Hi Team,
I have general qustion in n8n.
1.How to do scalability in n8n while active and running multiple n8n workflow ?
2.Is there any problem while receiving lots of request in n8n with lots of workflow in active state ?
3.What is the performance at that time ?
4.How to do Scalability in n8n ?
Can any one tell me the solution of those.
Thanks in Advance.
Thanks.
Hey @rajesh-kumar,
You can find the instructions on scaling n8n here: Scaling n8n | Docs
We also have a live stream recording explaining how it works: How to scale your n8n instance 🗻 - YouTube
Though they don’t answer all your questions, these resources are a good starting point.
Hey @harshil1712
Ok , Thanks a lot. If any doubts on this. let you know
Thanks Again.
