How to Eliminate Manual Data Entry in Business Travel Expense Management with Automation Workflow
Hey everyone :waving_hand:
I’m excited to share a new n8n workflow I’ve put together:
:backhand_index_pointing_right: Extract Data from Trip Receipts with GPT-4-1 Mini, Google Sheets, and Email Notifications
:link: Workflow: n8n.io/workflows/6896
It automates pulling structured data out of receipt images, logging them in Google Sheets, and sending email alerts.
:bullseye: What this workflow does
This workflow is all about automating receipt processing:
  • You supply receipt images (e.g. for travel)
  • Extract key data from them (dates, amounts, vendor, etc.) using GPT-4-1 Mini
  • Append the extracted data to a Google Sheet
  • Notify via email with a summary of what was extracted
:magnifying_glass_tilted_left: Step-by-Step Flow
  1. Trigger — Manually trigger or send in receipt images.
  2. OCR / Text Extraction — Use an OCR node (or image-to-text) to read the receipt content.
  3. Data Extraction — Send the extracted text to an OpenAI model (GPT-4-1 Mini) with a prompt to parse out structured fields: date, vendor, total, etc.
  4. Google Sheets — Write the structured data into a specified Google Sheet (add as new row).
  5. Email Notification — Send an email summarizing what was extracted (so you can verify, get alerts, or forward).
:gear: Requirements and Setup
  • OpenAI API key (configured in n8n)
  • Google Sheets credentials (with access to the target sheet)
  • Email node credentials (SMTP or provider setup)
  • OCR/image-to-text setup if receipts are in image format
:wrench: Possible Customizations
  • Trigger via web-hook or upload folder instead of manual trigger
  • Add vendor-specific prompt templates for better accuracy
  • Add validation (flag mismatched totals)
  • Store receipt images in GCS/S3 with links in sheet/email
  • Swap out email with Slack/MS Teams/SMS notifications
  • Batch processing on a schedule
:video_camera: Demo Video
I also made a walkthrough video so you can see exactly how it works:
Watch the demo
:light_bulb: Would love to hear your feedback:
  • Have you tried something similar?
  • What other data sources/outputs would make this more useful?
  • How would you extend this in your projects?
Thanks for checking it out :rocket:
cool video. How to Eliminate Manual Data Entry in Business Travel Expense Management with Automation Workflow is a topic many companies are starting to take seriously. Manual entry not only slows things down but also increases the risk of errors and lost receipts. By implementing automated workflows, businesses can capture expenses in real time using mobile apps and integrated systems. These tools can scan receipts, extract relevant data, and sync it مباشرة with expense platforms without human input. In the middle of setting things up, teams often look up things like Adobe phone number when dealing with document tools, but the goal is to reduce those manual touchpoints altogether. Automation also improves compliance by enforcing company policies automatically during submission. Over time, this leads to faster reimbursements and better visibility into spending patterns. Ultimately, removing manual processes frees up employees to focus on more valuable tasks rather than repetitive data entry.
