How to extract clean AI Markdown (with RAG chunks) in n8n without heavy scraping scripts
Hey everyone! :waving_hand:
If you build AI agents or RAG pipelines in n8n, you’ve probably faced this: fetching raw HTML with standard HTTP nodes fills your LLM context window with navigation menus, footer links, and cookie banners—burning up to 80% of your tokens unnecessarily.
To solve this for my own automation workflows, I built a lightweight API called WebPulse (hosted on Vercel and available on RapidAPI), and I wanted to share a simple, reusable n8n pattern that you can paste directly into your canvas.
What this workflow does:
  1. Takes any input URL.
  2. Sends it through WebPulse’s /api/v1/markdown endpoint.
  3. Returns:
    • Clean GitHub-flavored Markdown.
    • Formatted plain text.
    • Pre-split semantic rag_chunks ready to pipe directly into Vector Store or OpenAI/Claude nodes.
    • Exact token savings percentage (llm_token_savings_percent).
Copy-Paste n8n Workflow JSON:
You can copy this JSON block and paste it directly into your n8n editor canvas (Ctrl + V):
How to test it for free:
I’m an indie builder experimenting and building cloud tools in public from Santa Fe, Argentina. I would love to hear feedback from the n8n community—what additional data fields or extraction features would help your daily workflows?
