How to fetch one tool output as input to another input
I’m trying to load the output of the http tool into the code tool, but I can’t seem to figure out how to extract it. Any reference materials would be greatly appreciated.
Welcome to the community @ai_WithKallam !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
I would expect it to look something like this
The output of AI Agent would have a property output. You can refer to it in Code as _input.first().json.output.
However, you mentioned Code tool, not node. I don’t think you can chain tools. You would have to use another AI node and have Code tool connected to it as in
