How to fix: ERROR: Cannot read properties of undefined (reading 'split')
I do get this quite often. Do i need to do anything different?
  • n8n version: 0.228.2
    all default + docker
Hi @ManyQuestions, I’m very sorry you’re having trouble.
It’s hard to say what exactly causes this as you didn’t provide an example workflow using which this problem can be investigated.
However, on your screenshot it seems you are sending 20 items to your Edit Image node. I suspect that one (or more) of these items are simply missing one (or more) of the properties you are referencing in your Edit Image node.
