- **n8n version:lastest
- **Database (default: SQLite):default
- **n8n EXECUTIONS_PROCESS setting (default: own, main):own
- **Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
- **Operating system:windows
barn4k
2
hello @Thuy_Dang
according to the error, you don’t have available tokens. Check your quota in the openai portal.
How do I check my token usage? | OpenAI Help Center
rbreen
3
Hi @Thuy_Dang ,
Check if you have a balance on your openai billing page. Here’s the link. You need to have a credit balence for the openai step to work.
https://platform.openai.com/settings/organization/billing/overview
Best,
Robert
system
Closed
4
