Hi, everyone. I am going to get customer review of sellercentral.amazon. so how should i do? If anyone has experience, please let me know.
you can use customer feedback api for it:
and api’s can be called with http node.
Thank you for your reply. so The basic idea here is to find customer with 3 stars. Is that possible?
Hi, Could you help me?
I do not think you can get what you want.
but from above api given:
also check this out:
https://sellercentral.amazon.com/seller-forums/discussions/t/4cb171fe-f6ed-4a14-b8ae-1f1c2f69b97e
you can Also explore third party scrapping tools.
