how can i map data from input in my custome code function
drag and drop not working
Any one can help pleas let me know
Hi @Sale.Favourite_fab, in the Code node can simply call n8n’s built in methods and variables like any other JS variable. Once you have your result you’d need to make sure to return a valid n8n data structure.
Here’s a quick example workflow fetching data from a dummy API, then referencing it in a subsequent code node:
Hope this helps ![]()
