How to include an element inside the object with "node set"?
How to include an element inside the object with “node set”?
I’m making a request to report the recurrence of products in the order from the recurrence of customers, in order to generate a list of products.
It is necessary that an item with the purchase number be inserted into the purchase object in each item of the array.
for example:
"item":{
         "numeroPedidoLoja": "2000005891958290", //item to be inserted
         "codigo":"13545-C",
Below is the model of the array that I want to iterate and include the item “NumeroOrderLoja” of each purchase order:
"itens":[
      "item":{
         "codigo":" 13545-CT-9",
         "descricao":"Balança Digital Cozinha Receita E Dieta Precisão 1g Até 10kg Sf-400 Branco",
         "quantidade":"6.0000",
         "valorunidade":"7.8900000000",
         "precocusto":null,
         "descontoItem":"0.00",
         "un":"UN",
         "pesoBruto":"0.00000",
         "largura":null,
         "altura":null,
         "profundidade":null,
         "descricaoDetalhada":"",
         "unidadeMedida":"cm",
         "gtin":""
      "item":{
         "codigo":"13545-C",
         "descricao":"Balança De Cozinha Digital Electronic Sf-400 Pesa Até 10kg Branco",
         "quantidade":"4.0000",
         "valorunidade":"10.0000000000",
         "precocusto":null,
         "un":"UN",
         "largura":null,
         "altura":null,
         "gtin":""
Hey @hlf,
I am not sure what you are trying to do here, Are you trying to add numeroPedidoLoja to each item in the itens array?
exactly, but I would like to know if there is a way to do this directly within the “set node”?
Hey @hlf,
Not that I can think of, You would need to use a Code node to handle it… or maybe an item lists node to split itens then a set node to add it :thinking:
Yeah I guessed, I did exactly that with the item lists node. I asked the question if there was a possibility to do it directly with node set.
Hey @hlf,
In that case… no :slight_smile:
