How to input {{my.token}} in expression?
Hi, I have an expression in the body element on a http request node. However, in the body I need to insert {{my.Playbook}} as value. However, N8N thinks it’s an expression. How can I make sure that I can input {{my.Playbook}} without it being listed as an expression?
To clarify {{my.Playbook}} is not an expression, it’s the actual string I need to pass
Yes that is honestly not that simple and I also thought was at least a little bit simpler in the past. Anyway, you could do something like following:
{{ '{' + '{ my.Playbook }' + '}' }}
Perfect! Thank you Jan!
