How to integrate LLMs into workflow automation?
You went to a conference, saw a flashy demo of an LLM agent, and now you want to build your own. Welcome to the show! Take a seat and let’s look at how to actually integrate LLMs into workflow automation.
First thing: understand what your workflow has to do before you build it. Only then can you see where an LLM genuinely helps and where it’s just expensive decoration.
Where LLMs actually shine
Intent classification and routing. LLMs are very good at pulling structure out of unstructured text. An agent can, for example, read a support ticket and work out which area of the product it belongs to: technical, user experience, authentication, billing
Structured data extraction. Give it text, get back clean JSON. The deterministic alternative is regex, which works, but it’s high maintenance: you have to be a bit of a clairvoyant up front, and then keep patching the pattern every couple of days.
Retrieval. Paired with a RAG system, an agent gets very good at finding things in a large corpus of information, provided that the data is indexed properly. Sticking with tickets: load your ticket history into a vector database and give support technicians an agent that surfaces similar past cases. Plenty of problems have already been solved once.
Policy and compliance checks. An agent can spot PII in a text and classify or redact it according to your company’s policy.
Artifact generation. Documents, summaries, or code generated dynamically for the rest of the workflow or the team to consume.
That’s not an exhaustive list, just the patterns I keep coming back to.
Before you push it to production
Repeat after me: “Hallucinations exist”. Newer models hallucinate less, but less is not zero. If a model has a 0.1% chance of going off the rails on a single run, then at production volume, thousands of executions or conversations, hallucinations become a certainty.
They also can’t be removed. They’re a property of the same architecture that makes the model work in the first place. What you can do is ground the output and catch the bad ones before a user ever sees them.
Output parsers are the cheapest way in. In n8n, switch on Require Specific Output Format in the AI Agent node. That unlocks a sub-node where you pick a structured output parser and hand it a JSON schema, and the agent is then forced to answer in that shape. You can also enable auto-fixing: if the output doesn’t match the schema, a second prompt goes back to the model asking it to correct itself. It works, but it costs you an extra call in both latency and tokens, so use it where it earns its place.
Practices worth making non-negotiable
Force structured output. JSON schema validation on the way out, either with a parser or a Code node doing the validation yourself. Just do it.
Validate between steps. Check the schema, use confidence thresholds, and decide whether the flow is allowed to continue. That’s how you intercept a failure before it becomes a tool call, a sent email, or a database write.
Human in the loop. High risk actions get escalated for approval before execution. No exceptions.
Low temperature. Somewhere between 0 and 0.3 or 0.4 for anything operational. You want grounded, not extravagant.
Route before you generate. Evaluate the request first, then decide dynamically which model handles it, which agent, and how much authorization that agent gets. Not every request deserves your most expensive model or your widest set of tools.
And now, for the grand finale:
AI agent demos are flashy. That’s what demos are for. But every LLM you drop into a workflow adds a chance of failure that a deterministic node simply doesn’t have.
So before you put an agent in the middle of your automation, ask yourself whether the job actually needs one, or whether good old fashioned deterministic logic would do it faster, cheaper, and exactly the same way every single time.
I’m gonna be honest with you: half the time, it does.
