How to integrate with DigitalOcean's GenAI Platform?
I am trying to configure a new credential for my GenAI platform in Digital Ocean.
Couldn’t connect with these settings
Not Found
None to share as this is a credential
  • n8n version: 1.80.4
  • n8n EXECUTIONS_PROCESS setting (default: own, main): N/A
  • Operating system: Ubuntu 24.10 x64
Hey @authex To connect n8n to DigitalOcean’s GenAI Platform API, you can utilize the HTTP Request node in n8n.
HTTP Request node
hi @authex DigitalOcean’s GenAI Platform doesn’t have direct integration with n8n yet, but you can connect using HTTP Request nodes:
  1. Create a Generic API credential:
  2. Use HTTP Request node with these settings:
Method: POST
URL: https://api.digitalocean.com/v2/ai/completions
Authorization: Bearer Token
Token: {{$credentials.DigitalOcean_GenAI.apiKey}}
Headers: Content-Type: application/json
Body (JSON):
  "model": "llama3-70b-instruct",
  "prompt": "Your prompt here",
  "max_tokens": 500
  1. For different operations:
  • Text completions: /v2/ai/completions
  • Embeddings: /v2/ai/embeddings
if my comment helped solving your question please consider marking it as solution that would be a great help, and few likes would make my day.
Thank you
@jan — any chance the n8n team is working on either a generic chat model component that’s widely configurable (endpoint, keys, etc) or a specific Digital Ocean GenAI platform chat model component?
