Hello,
I’m new to n8n and I’m having problems with the aggregate node
I have searched for information on the internet about the aggregate node but I cannot find it since it is a new node. All information is centered on the previous item list node.
As you can see in the left part of the image, with the htt request1 node I make a query to an API that returns 4000 paginated records of 50 objects within an array (data).
I want to have the 4000 together again. That’s why I used the aggregate node to join them. But it gives me the result on the right side of the image.
I don’t know if I’m using the wrong node or doing it wrong.
Please help. Thanks
- n8n version: 1.66.
- Database (default: SQLite): Postgres
- Operating system: Ubuntu
