Clicking the orange button “Test workflow” at the bottom of the workflow editor seems to initiate the webhook to listen for incoming requests. How do you test the workflow when you want to initiate it from the manual trigger?
n8n version: 1.27.3
Database (default: SQLite): SQLite
Running n8n via (Docker, npm, n8n cloud, desktop app): npm
Thank you @jan - are there other options to achieve this? Temporarily disabling the webhook node is not really an option because it serves as a callback to receive the result from a call to an external web service.
You can disable the webhook and test the workflow. Your production won’t be affected until you press the Save button
Another option is to duplicate the workflow and remove the webhook there. That one is safer way to test something while your production is doing it’s job
