Hi, im trying to nest two split in batches, because i have the following workflow (reorder computer on Active Directory OU’s based on computer name patterns) steps:
- Retrieve from Google Sheets a table (column 1: pattern, column 2: destination OU)
- Per each row
** Retrieve all computers using LDAP node in my Active Directory all computers that have a matching pattern in the computer name.
** Per each retrieved computer from Active Directory:
*** If actual organizational units (distinguishedName) doesnt end in the actual column 2 (destination OU) of Google Sheet: move computer to “destination OU of Google sheets” else, do nothing.
I cant get the workflow to work properly, all the rows from google sheets gets compared with alls results from LDAP (i want a normal nested behaviour to happen as in a programming language).
Please share the workflow
Because the workflow uses n8n-nodes-ldap, I share the actual filter search in LDAP:
(&(objectClass=computer)(name={{ $json["Nomenclatura"] }}))
- n8n version: last (queue mode)
- Database you’re using (default: SQLite): postgresq
- Running n8n with the execution process [own(default), main]: own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker, k8s
