Im learning how to use the memory in order to store some flow data during execution. Im looking for the best way to unify lastStates and lastTimestamps into one single entity to later delete records where timestamp is older than 24 hours.
My code node is currently storing this in memory:
"debug_lastStates": {
"1234567": "Preparacion"
"debug_lastTimestamps": {
"1234567": 1754366490
I would like to adjust it so it stores it this way:
"debug_lastData": {
"1234567": {
"state": "Preparacion",
"timestamp": 1754366490
This is the current code node i have (Python) which works ok but saves the same id with mergeable data in separate structures.
import time
# Obtengo la memoria global del workflow
workflowStaticData = _getWorkflowStaticData('global')
# Inicializo lastStates si no existe
if 'lastStates' not in workflowStaticData:
workflowStaticData['lastStates'] = {}
# Limpieza de entradas antiguas (TTL de 48h)
TTL_SECONDS = 24 * 3600
now = int(time.time())
# Usamos una estructura auxiliar para guardar timestamps
if 'lastTimestamps' not in workflowStaticData:
workflowStaticData['lastTimestamps'] = {}
lastTimestamps = workflowStaticData['lastTimestamps']
# Borramos claves expiradas
expired_keys = [
k for k, ts in lastTimestamps.items()
if now - ts > TTL_SECONDS
for k in expired_keys:
workflowStaticData['lastStates'].pop(k, None)
lastTimestamps.pop(k, None)
# Recojo todos los items como lista Python
items_to_notify = []
all_items = _input.all()
# Itero y comparo estados
for itm in all_items:
data = itm['json']
key = str(data['IdAtencion'])
current = data['Estado'].strip()
last_state = workflowStaticData['lastStates'].get(key)
telefono = str(data.get('TelAcompanante', '')).strip()
sede = str(data.get('Sede', '')).strip()
# Si no había notificado o cambió de estado:
if last_state != current:
# a) Actualizo la memoria global
workflowStaticData['lastStates'][key] = current
workflowStaticData['lastTimestamps'][key] = now
# b) Marco este ítem con solo los campos requeridos
items_to_notify.append({
'json': {
'Paciente': data['Paciente'],
'TelAcompanante': telefono,
'Estado': current,
'Sede': sede
# Devuelvo sólo los ítems que requieren POST
return items_to_notify
- n8n version: 1.97.1
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: Debian
