How to post to Facebook with n8n
Thanks for this tutorial, but I follow all the steps but still have a problem mentioned on this link
I’m getting “(#200) This endpoint is deprecated since the required permission publish_actions is deprecated” if I’m testing it, do you have any solution for that?
I have already given all Permission over Graph API Explorer and copied the scret from there.
n8n version : 1.72.1
Database : default
n8n Executions : default
Running n8n via : Docker
Operating System : Linux
I think it might caused by using the wrong token type. Be sure to use a page token, not a user token.
Not sure if this is what you ran into but posting a FB Group via API is no longer allowed by Facebook. (As of April 2024)
Thank you for your sharing! Let me try it.
I had the same problem and figured it out by redoing the app in meta developer and adding these four options: pages_show_list, business_management, pages_read_engagement, pages_manage_posts, public_profile
Hi, I tried to find the public_profile anywhere but seem like they removed it. How about your system?
Why do you have to have a developers account to do a simple post request to a facebook page? I can do that in dozens of programs without having to setup with developers… What am I missing?
Thank you for posting this tutorial, also do you have tutorial for automate comment , thanks!
Unfortunately this does not work. I get this error:
If posting to a group, requires app being installed in the group, and \ either publish_to_groups permission with user token, or both pages_read_engagement \ and pages_manage_posts permission with page token; If posting to a page, \ requires both pages_read_engagement and pages_manage_posts as an admin with \ sufficient administrative permission
I have granted all of these permission. However, when I select page access token, login and click on generate token, it always jumps back to user token. So I assume it does not create the page access token.
Does anybody has a solution for this?
Have you found a way to upload posts or videos to FB Groups & Pages?
