At the end of a n8n form submission, I want to retrieve some data coming from the flow, and display them to the user.
I don’t think it is possible, but would like to make sure.
Is there a workaround?
Arigato gozaimasu @barn4k
This is exactly what I was looking for.
For those who might be interested, to display a custom page after the submission of an n8n form, at the end of the workflow, using a Respond to Webhook node, you should choose to Respond with “Text”.
It’s interesting to note that you can pass any HTML you want, but you cannot change the head tag. It will be removed, so you can only pass the content of the body tag.
Here is a sample workflow that displays a confirmation with both variables from the form and the workflow.
