How to run python script in virtual environment?
I’m trying to run a python script in a virtual environment using the Execute Command node but it gives error. I tried testing the command in putty and it works but it doesn’t work within n8n. I can’t activate the virtual environment.
Command failed: source /var/www/comic.adoreanime.com/htdocs/project/bin/activate /bin/sh: 1: source: not found
  • n8n version: 2.0.3
  • Operating system: Ubuntu 24.04 LTS
In n8n’s Execute Command node, the command is executed with /bin/sh by default
source is a bash builtin, and does not exist in /bin/sh
That’s exactly what this error means:
Use the Code node to run python script
I can’t use the Code node cause the python script is complicated so I want to run it externally
instead of using source which is not available for linux’s /bin/sh, you can use POSIX Standard which is a dot ( . ) which should work
change this
to
. /var/www/comic.adoreanime.com/htdocs/project/bin/activate
