Zoker
January 27, 2025, 2:30pm
1
I want to send a SMS directly to a number with the AWS SNS node.
With apprise I can directly send one:
With n8n I only have the option to publish something to a topic. But that’s not what I want to do.
How can I do that with n8n? Thanks!
n8n version: 1.76.0
Database (default: SQLite): SQLite
Running n8n via (Docker, npm, n8n cloud, desktop app): docker
Operating system: alpineos
gualter
February 3, 2025, 11:33am
2
hi @Zoker
Unfortunately that seems to be the only supported operation as per our docs, have you tried usnig an http request directly as suggested here: AWS SNS node documentation | n8n Docs
Hope this helps!
Zoker
February 3, 2025, 12:16pm
3
Hi @gualter ,
I already created a PR for this feature here:
n8n-io:master
← TheZoker:add-direct-publish-sns
opened 03:48PM - 27 Jan 25 UTC
## Summary
Describe what the PR does and how to test.
Photos and video… s are recommended.
This PR adds a new option, to send a message directly to a phone number via AWS SNS.
This function is described in the AWS docs:
https://docs.aws.amazon.com/sns/latest/dg/sms_sending-overview.html#sms_publish-to-phone
## Related Linear tickets, Github issues, and Community forum posts
This solves my own request/question in the community:
https://community.n8n.io/t/how-to-send-an-sms-with-aws-sns/73028
Include links to **Linear ticket** or Github issue or Community forum post.
Important in order to close *automatically* and provide context to reviewers.
## Review / Merge checklist
- [x] PR title and summary are descriptive. ([conventions](../blob/master/.github/pull_request_title_conventions.md)) <!--
**Remember, the title automatically goes into the changelog.
Use `(no-changelog)` otherwise.**
- [ ] [Docs updated](https://github.com/n8n-io/n8n-docs) or follow-up ticket created.
- [ ] Tests included. <!--
A bug is not considered fixed, unless a test is added to prevent it from happening again.
A feature is not complete without tests.
- [ ] PR Labeled with `release/backport` (if the PR is an urgent fix that needs to be backported)
system
Closed
May 4, 2025, 12:17pm
4
