Hello, could anyone help me?..
I’m building a custom node, and it does automatic pagination, I want that when the user stops the workflow, the node shows some data output that is what has already loaded from the pagination. Can anyone help me and know if there is a way to do this?
- n8n version:
- Database (default: SQLite):
- Operating system:
Hey @Jose_Henrique,
Welcome to the community ![]()
If a workflow stops the node won’t return so you won’t get any data back, This is something that will be an issue with all of our nodes with no current workaround without a core change.
What is the goal with seeing data when you press stop?
