How to use a variable within a text variable
I have a variable that has a prompt and within that prompt there is a variable from n8n, how to show it in n8n, but it remains as text, how do I show it as a variable
Debug info
core
  • n8nVersion: 1.50.0
  • nodeJsVersion: 20.15.0
  • database: postgres
  • executionMode: scaling
  • concurrency: -1
  • license: community
  • consumerId: unknown
storage
  • success: all
  • error: all
  • progress: false
  • manual: true
  • binaryMode: memory
pruning
  • enabled: true
  • maxAge: 72 hours
  • maxCount: 10000 executions
security
  • blockFileAccessToN8nFiles: false
Generated at: 2024-07-20T16:14:26.049Z
@Ruan17 , the issue you are trying resolve is not quite clear to me. Thus, I will try to cover all the scenarios I can think of. Below is the demonstration how to handle n8n variables inside the text.
Depending on where you stand the solutions are
Use expression making sure you turned it on
Evaluate text as an expression
Using $evaluateExpression() (see Convenience methods | n8n Docs).
Excellent, $evaluateExpression worked perfectly, I had never seen this function in n8n, and thank you for sending the support page, I will study it again, I thought I hadn’t updated it and taking advantage of it, do you have any links that help make better prompts within n8n?
