How to Use Credentials as Variables in n8n’s Code Node: A Simple Workaround
In n8n, while it’s not possible to directly use credentials as variables in the Code node, there’s a simple workaround.
You can store encrypted credentials in a SQL database, retrieve them using the SQL node, and then decrypt them in the Code node. This method ensures your credentials remain secure while still being usable in your workflow.
Don’t forget to not save the executions when doing this. As this would be showing the credentials in plain text :wink:
Thank you for pointing that out!
how do you decrypt credentials in code node ?
