How to use cURL
Hello guys, i’m trying to use a cURL onliner command to send a contract in eSignature.io, but i need some help.
eSignature show me this cURL: curl -X POST “https://esignatures.io/api/contracts?token=your-token” -X POST -d ‘{“template_id”:“contract_template”, “signers”:[{“name”:“Sam Signer",“email”:"samsigner@email.com”}]}’
How can i use this cURL in n8n to do my automation???
I’m using HTTP Request node.
Thank you!
  • n8n version: 0.168.2
  • Database you’re using: SQLite
  • Running n8n via:n8n.cloud
Yes, you can do this using HTTP Request Node.
Make sure the JSON/Raw Parameters is selected and Under the Body Content-Type JSON is selected.
Then paste the JSON stuff under Body Parameters.
If you’re not having nested JSON data. you can directly use body parameters
Example workflow:
Thank you so much!
It helped me a lot. :smile:
Hi.
I need to do authorization in curl, how do it using HTTP request? Example:
Hey @tomfat,
That is using the user option so you could either create a new credential using basic auth for that value or in the HTTP Request node add a header with a name of Authorization and a value of Basic NDA2Z..... and that should do the job.
