I am trying to create a ticket using the osTicket API, which supports adding attachments into the ticket via JSON: Tickets — osTicket 1.17.1 documentation
However, I am unsure how to read the raw Binary data of my CSV into the attachment field. When I try to specify using the input from the previous Spreadsheet node it just populates the file with Output output
instead of the actual data.
Please share the workflow
- n8n version: 0.203.1
- Database you’re using (default: SQLite): Postgres
- Running n8n with the execution process [own(default), main]: own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: K8s
