I’m trying to understand how split in batches node works, this is a basic example that I’m working on
So I’m tying to fetch 1 by 1 the cities that are return by the function node
Hey, @Juan_Gabriel_Fraire welcome to the community, I think you can do what you want to do without using the split baches node. Check the example below. Just add your apiKey under appid and then execute the workflow.
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
340,
350
"parameters": {
"functionCode": "return [ { json: { city: 'orlando' } }, { json: { city: 'miami' } } ]\n"
"name": "Function",
"typeVersion": 1,
"position": [
590,
350
"parameters": {
"url": "http://api.openweathermap.org/data/2.5/weather",
"options": {},
"queryParametersUi": {
"parameter": [
"name": "appid",
"value": "01051d1267e38c490bcc447d3a18f738"
"name": "q",
"value": "= {{$node[\"Function\"].data[\"city\"]}}"
"name": "HTTP Request",
"typeVersion": 1,
"position": [
890,
350
"connections": {
"Start": {
"main": [
"node": "Function",
"type": "main",
"index": 0
"Function": {
"main": [
"node": "HTTP Request",
"type": "main",
"index": 0
Thanks!, But my question was more related to understand the tool better, and from the conclusion maybe improve the documentation about how to do use it. I mean maybe we should point people to use more function nodes instead, that’s also a valid answer.
I see @Juan_Gabriel_Fraire , execute this example and you will catch the execution flow and hopefully how to use the node.
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
340,
340
"parameters": {
"name": "Function",
"typeVersion": 1,
"position": [
590,
340
"parameters": {
"batchSize": 1
"name": "SplitInBatches",
"type": "n8n-nodes-base.splitInBatches",
"typeVersion": 1,
"position": [
840,
340
"parameters": {
"conditions": {
"boolean": [
"value1": "={{$node[\"SplitInBatches\"].context[\"noItemsLeft\"]}}"
"name": "IF",
"type": "n8n-nodes-base.if",
"typeVersion": 1,
"position": [
1190,
70
"parameters": {},
"name": "Function1",
"typeVersion": 1,
"position": [
1410,
330
"connections": {
"Start": {
"main": [
"node": "Function",
"type": "main",
"index": 0
"Function": {
"main": [
"node": "SplitInBatches",
"type": "main",
"index": 0
"SplitInBatches": {
"main": [
"node": "IF",
"type": "main",
"index": 0
"IF": {
"main": [
"type": "main",
"index": 0
"node": "Function1",
"type": "main",
"index": 0
Thanks!! I will give a try and maybe document it.
Hey @Juan_Gabriel_Fraire!
It’s been long, and we have made a lot of improvements to n8n ![]()
I was wondering if you needed more help here. If not, I will close this topic ![]()
