Hi I’m a beginner with n8n and javascript. I’m trying to put variable from previous node in the code node.
- I tried pasting parameter path and item path.
- tried removing their curly braces, and encapsulating them in list.
- nothing works. some errors I’m getting are output. Item didn’t returned properly and position error.
I’m pretty confused how to use variables in here. I tried same code with other IDE’s they run perfectly.
My usecase is to strip some part from my input. I have the code for it, but just help me use variables in code node and also guide me if there’s anything else I need to know to code in n8n.
