How use n8n connect with Comfyui for generate image and vdo?
I’m interested in using n8n to create an image or video that calls an api to comfyui locally. Can anyone suggest how to connect to comfyui?
Full disclosure, I haven’t personally used ComfyUI before. However, I have successfully installed and run various community nodes on my self-hosted n8n instance, so I can speak to that part.
First, a quick reminder: to install community nodes (custom nodes not built into n8n by default), you’ll need to be running your own self-hosted n8n instance . This feature isn’t available on n8n’s cloud plans.
If you have a self-hosted setup, it looks like there’s a community node specifically for ComfyUI that should help you out:
