I am using a basic HTML extraction node. The problem is that the elements “\n” in the html input seems to be changing position in the content between the input and output.
- n8n version:
- Database (default: SQLite):
- Operating system:
- n8n version:1.52.2
- **Database (default: SQLite): Xano
- **n8n EXECUTIONS_PROCESS setting (default: own, main):no idea
- **Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
- **Operating system:windows
Welcome to the community @Paul_colean.io ![]()
Could you paste parts of the original HTML text you’re extracting the text from or pin your data before sharing?
