can anyone tell me the difference between these two nodes for extraction of HTML CSS etc.
As far as I know the only difference is the updated version allows you to create and preview HTML.
Are you seeing a difference when using them?
No I’m not sure if the difference and why I’d use one over the other, just wanted to understand if I should use the newer html node
I would say use the new one but only because we have removed the old one from the node list. It is the
The …
But do i need to replace them in old workflows?
Nah you can keep what you have, We don’t have any plans to remove the old node at the moment.
