I am trying to connect to the API for a smart device.
It works in my browser but I get 504 errors when trying to connect within n8n. I’ve configured digestAuth credentials which work fine in my browser when tested.
A 504 is normally a timeout of some kind rather than a credential issue, it could be that the api you are using incorrectly responds with a 504 or it could be an odd header issue.
What version of n8n are you running and how do you have it installed?
Hey @Jon running 0.152 via docker. Other HTTP requests are working fine so I’m stumped
Updated to add:
I’ve taken a closer look at the request from my browser and it has more info in the header fields. Maybe I need to include some of this with my request from n8n?
Can you try adding a new environment variable for the option below to see if it helps (will need a container restart). If it doesn’t help remove the environment option.
