HTTP Node Issue w/ Go High Level
Trying to fetch contacts in high level based on last name by using an HTTP node that is setup using header auth. The API i’m calling expects a valid JWT (JSON Web Token) in the request headers, but the token provided is missing, expired, or malformed. Not sure why as i’ve pasted the api key from the location settings in the high level sub-account with “Authorization” as the name and the value being “Bearer ”.
Authorization failed - please check your credentials
Invalid JWT
From HTTP Request
Error code
401
Full message
401 - “{"statusCode":401,"message":"Invalid JWT"}”
Request
{ “body”: { “query”: “Geddes”, “limit”: “20”, “locationId”: “7NU58m4inuzycZkzBZ3Z” }, “headers”: { “version”: “2021-07-28”, “Authorization”: “hidden”, “accept”: “application/json,text/html,application/xhtml+xml,application/xml,text/;q=0.9, image/;q=0.8, /;q=0.7” }, “method”: “POST”, “uri”: “https://services.leadconnectorhq.com/contacts/search”, “gzip”: true, “rejectUnauthorized”: true, “followRedirect”: true, “resolveWithFullResponse”: true, “followAllRedirects”: true, “timeout”: 300000, “encoding”: null, “json”: false, “useStream”: true }
Hey @cgeddz !
Why don’t you use HighLevel predefined credential type (API key / OAuth2).?
It handles the JWT .
However if you wanna stick with your Bearer to be sent trough header I think this is the proper way of using them directly :
As discussed here:
I suppose the type of credential you are usin is just sending a string … and not the JWT .
Cheers!
