HTTP problem
I was creating a chatbot with evolution api but for some reason the http node starts to send multiple messages in whatsapp ando i don’t know how to fix it. For example i write hello and the chatbot start to send multiple messages without stopping
Hi @Nicolas_Angulo hope all is well.
Would you like to show us a screenshot of one such execution (from under the Executions tab)?
Nodes have ‘Execute Once’ option in their settings (Refer to image). By default it is toggled off so may be you can activate it and see if it works with you that way.
Hello jabbson TikTok - Make Your Day Here I Leave you the video of what is happening
