HTTP Request node, batching does not work
Hi guys,
i’m having an input
{“id”: 1}, {“id”: 2}… 998 more
im trying to use option batching, to basically send 10 requests (each with 100 ids) in a single call (basically im doing batch get with 100 ids inside a json body).
I was able to solve this by using “Loop Over Items” with batching 100 and then using Run only once on the http node and $input.all in a request body.
Im trying to solve this without using Loop Over Items… is this even possible?
Thanks a lot
[email protected]
n8n cloud
Welcome to the community @Goran_Popovic !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
I tried batching option and all seem to work as expected. Below is the demo workflow and the screenshot showing the result of such operation.
There are 5 items for simplicity. The batch is 2 items with 1 min delay.
@ihortom thanks for your answer.
So yes, it will correctly batch requestions and then wait… but it will not actually batch $json input right?
So i want the request to contain ID1 and ID2, i have to use “Loop over Items?”
I’m not sure I’m following this question. To batch $json input the HTTP Request node would be configured as below, for example.
You do not need Loop for that either. I do not know what ID1 and ID2 imply but they could be added to your items before you feed them into HTTP Request.
Though, it you want the batch number to be included with each item POSTEed with HTTP Request node then yes, using the Loop makes sense as looping that way implies many iterations and each one could be labeled by means of $runIndex variable.
