Https (webhook-)urls for self-hosted-starter-kit
Using the self-hosted-ai-starter-kit, I encountered a problem with the Telegram Trigger node. As far as I understand, the Telegram API requires the webhook URL to use a HTTPS address but the self-hosted-ai-starter-kit is not configured that way (not out of the box, at least). My webhook urls currently look like this: “**http://**localhost:5678/webhook-test/…/webhook”.
I am looking for a pragmatic approach to adjust that. I wasn’t successful finding any documentation about this specific setup.
Telegram Trigger: Bad Request: bad webhook: An HTTPS URL must be provided for webhook
400 - {“ok”:false,“error_code”:400,“description”:“Bad Request: bad webhook: An HTTPS URL must be provided for webhook”}
  • n8n version: 1.68.0 (self-hosted-ai-starter-kit)
  • Running n8n via: Docker
  • Operating system: Windows 10
Ok, interesting, I found something in the n8n documentation in the hosting context: n8n with tunnel
To be able to use webhooks for trigger nodes of external services like GitHub, n8n has to be reachable from the web. n8n has a tunnel service which redirects requests from n8n’s servers to your local n8n instance.
If I am not mistaken, this sounds like (part of) the solution I am asking for. Would this also solve the https aspect of it?!
Hey @Ingo,
I would use ngrok or Cloudflared as a tunnel option as it would be quicker, The other option would be to follow the normal documentation and configure a reverse proxy to handle the connection.
