Hi @joeldeteves, I am sorry to hear you’re having trouble. Do you by any chance have multiple triggers/webhooks registered with Hubspot? Iirc, they only allow a single webhook URL, so trying to register or manually execute any other trigger would disable the previous one.
Hi @MutedJam I only have the one workflow as shown in this post. The trigger itself seems to work fine with multiple Events specified - except for the Lifecycle Stage in which case nothing happens
I see. Could you double-check the webhook subscriptions for your app in your Hubspot developer account? There should be a list of all event subscriptions and you can view the details for each event. The Lifecycle Stage property is referred to as lifecyclestage for me:
