Hubspot Trigger does not fire for Property Change
I am trying to fire a Hubspot Trigger when a Deal Property changes in Hubspot - the authentication is good but is there something special to do to use Hubspot Triggers
No errors
“nodes”: [
“parameters”: {
“eventsUi”: {
“eventValues”: [
“name”: “deal.propertyChange”,
“property”: “solutions_engineer”
“additionalFields”: {}
“type”: “n8n-nodes-base.hubspotTrigger”,
“typeVersion”: 1,
“position”: [
0,
0
“id”: “e8229b84-3d68-43a1-8a5b-7d4f1dc25d28”,
“name”: “HubSpot Trigger”,
“webhookId”: “ff553405-d997-4976-9f2e-0031a870a57a”,
“credentials”: {
“hubspotDeveloperApi”: {
“id”: “qtWrDlb8wrUutXPX”,
“name”: “Production - Hubspot - Elesh Mistry”
“connections”: {},
“pinData”: {},
“meta”: {
“instanceId”: “911a64da27907bf497df03111ecbeab06ef36408d6edeb79a5551f281b818b7d”
  • n8n version:1.102.4
  • Database (default: SQLite):n/a
  • n8n EXECUTIONS_PROCESS setting (default: own, main):n8n cloud
  • Running n8n via (Docker, npm, n8n cloud, desktop app):n8n cloud
  • Operating system:n/a
I’m having the SAME issue. Glad it’s not just me. It just started happening about two weeks ago. It was working fine before that.
I’m having a similar issue. For me, the HubSpot Trigger never fires automatically when the event happens unless I first click “Execute Node” and then manually create the event (e.g., create a company) in HubSpot while it’s listening.
Once I stop executing the workflow manually and leave it in Active mode, no events from HubSpot seem to trigger it anymore.
I’m experiencing the same issue. Were you able to find a resolution for this? @N8n Could you please help me with it?
