For evaluating n8n I am running n8n self hosted on a linux (debian) machine in docker container:
docker volume create n8n_data
sudo -u dockeruser docker run -d -it --name n8n -p 5678:5678 --restart=always -v n8n_data:/home/node/.n8n docker.n8n.io/n8nio/n8n
accessing it via localhost:5678 works well.
When I try from a different PC via the IP-Adress http://192.168.150.174:5678/ the login works but the Workflow Dashboard does not load fully. It looks like this:
When i click around (e.g. Settings->Users) i get error messages:
Could not check if an api key already exists.
Unauthorized
ResponseError
Unauthorized
Unauthorized
here is a sceenshot:
Any suggestion what I am doing wrong.
Thanks!
