I built an AI SDR system using n8n,Docker, Inc, Ollama,HubSpot that responds to inbound leads in under 5 minutes — automatically
I built an AI SDR system using n8n,Docker, Inc, Ollama,HubSpot that responds to inbound leads in under 5 minutes — automatically.
Instead of manually handling leads, the system:
Instantly detects new inbound requests
Uses AI to generate human-like replies
Scores lead intent (hot / warm / cold)
Automatically updates CRM records
Triggers personalized follow-ups
The result:
→ Lead response time reduced from ~24 hours to under 5 minutes
→ 100% automated qualification + routing
→ Every lead gets a personalized response instantly
→ No manual SDR involvement needed for initial touchpoints
This isn’t just automation — it’s a shift toward autonomous revenue systems where AI handles the first layer of sales conversations.
I built it using workflow automation + AI models + CRM integration.
ai #Automation #GTM #SalesAutomation #RevOps #SaaS #Startup #BuildInPublic #ArtificialIntelligence #n8n #Entrepreneurship
The ollama llm isn’t as good as claude or openai, when i changed it the results changed drastically
