I have 500 “items” that are the output from an expensive API. I had to cancel the workflow because I realized I was getting charged. The workflow cancelled before the step in which I put the api responses into my warehouse. How can I either download the node output items or continue the workflow and process them all? One I click test workflow - it only does 1 item and resets the entire output.
- n8n version:
- Database (default: SQLite):
- Operating system:
n8n Cloud fyi
