I didnt receive Badges of Course Level 2
Hello! I completed the Level 2 course but haven’t gotten the certificate yet. Is there any way to get it ?
Thank you
Hi, i am in the same situation. Did you get your certificate?
Hi, no unfortunately not. Not sure what to do at this point.
I have a similar problem :slight_smile:
Same issue too:
Hello @thierry1208 & @Phernan,
Your progress has been verified and your badge assigned.
cheers
Great, thank you Jamie!
can you tell me what means “Notifying” the team? I think I missed that part :frowning:
This is the discord part of the course. Ensure that you are using the correct message format as per the lesson instructions.
Thanks, I figured it out — I just needed to set up Discord first.
Hello @jamiemadden_n8n I have completed the course level 2 but did not receive the badge, could you please check? Thank you in advance.
Here is my unique ID 156dcee16ddd0914024f6d9a110586ab @jamiemadden_n8n
As you can see in the verification, you seem to have missed the first workflow task. This needs to be recorded for your badge to be awarded.
