I have completed Lvl 2 course, but I have problem acquiring the badge
I have completed the quiz and the getting data from the warehouse part. And even though i Have run the workflow I didnt get the badge.
Unique ID: 85c6bb7c535c81ec6d03f108bd25b0c1
I also had the same problem with the LVL 1 course a few days ago.
Please someone help. @jamiemadden_n8n
Hi @gtarasidis, can you show us the output of your Discord node? Basically, what exactly have you sent as a message? Notifying the team only causes trouble when the message sent is not in the correct format. Or maybe this can be a native issue which has is happening from a couple of weeks with the n8n text courses, so your progress does not gets synced with your unique_id.
It can also happen if wrong webhook was used
@gtarasidis, can you check if you are using the correct webhook?
@gtarasidis, please consider reading this:
As your second message I created the spreadsheet. lacks the filename, add a filename and then try again.
YES!! Thank you that was the problem i was using another discord url and not the n8n one
cheers !!!
If my reply helped, please mark it as the solution. Thank You!
Congrats!! I see you have earned your lvl2 badge :partying_face:
