I have problem using youtube upload node
Hi, sorry, it seems I have the same problem that others have but can’t do it for myself, I have the same problem as in this topic YouTube upload is failing
The videos are uploaded in draft mode, I guess it is not a valid file for youtube input, I have actually read and re-read many topics on the community about this problem
Here is the configuration added in my .env file
Request failed with status code 400
Thông báo lỗi ở node youtube:
AxiosError: Request failed with status code 400 at settle (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/core/settle.js:19:12) at IncomingMessage.handleStreamEnd (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/adapters/http.js:599:11) at IncomingMessage.emit (node:events:531:35) at endReadableNT (node:internal/streams/readable:1696:12) at processTicksAndRejections (node:internal/process/task_queues:82:21) at Axios.request (/usr/local/lib/node_modules/n8n/node_modules/axios/lib/core/Axios.js:45:41) at processTicksAndRejections (node:internal/process/task_queues:95:5) at invokeAxios (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:586:16) at Object.httpRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:771:20) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Google/YouTube/YouTube.node.js:616:50) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:741:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:724:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1155:20
  • n8n version: 1.72.1
  • Running n8n via (Docker,):
  • Operating system: Docker on Ubuntu 22.04
Is there anyone out there, help me!
Hey @KimClub
Are you saying that the videos are not uploaded at all? Have you checked that your credentials are working correctly? Could also be worth checking your GCP quota.
i had exactly the same problem, i remember it worked with the n8n cloud version, but not on my own server. I found this solution here and it worked for me! Title: Error 400 with Upload Video to YouTube Node - #7 by Matheus_Terra
Tôi đang sử dụng các node http để thực hiện việc đăng video lên youtube!
Hi Kim,
just seen your 400 Youtube error problem.
check these instructions:
Step 3.2: Starting n8n in Docker you basically have to add:
-e N8N_DEFAULT_BINARY_DATA_MODE="filesystem" \
to your instance then the native upload function works.
Thanks you, this is one of the important operations, and everyone needs to pay attention that we have to reset docker if you use docker-compose to run n8n
