Hello I need help to successfully send JSON via http request PUT. I have my last node which is an http request however I cannot automate the body, so that it retrieves the data in Input. if I copy and paste the json in RAW into the body it works well, but I don’t want to do this copy and paste. is there an expression that allows you to retrieve the entire json and send it?
I use the desktop version and so I gave you a screenshot to see the last node.
- n8n version: 1.37.3
- Running n8n via desktop app
- Operating system: Mac OS
